FpBlack Oil feed setup
Old Apr 1, 2010 | 02:41 AM
4ukc's Avatar
Just recieved one, and I am thinking about instalation.
Black is coming with oil feed line direct from filter, but usually turbo is feeded from head. I understand that from filter there will be more oil presure, but I was just interested in how other people did.
Old Apr 1, 2010 | 04:38 AM
RyuEvoIX's Avatar
Follow FP's instructions unless you dont mind the risk of destroying a $2000 turbo.
Old Apr 1, 2010 | 04:51 AM
1NastyMR's Avatar
There is a reason Fp stock frame turbos run from the oil housing... Follow the directions for the install and you wont have problems
Old Apr 1, 2010 | 06:30 AM
4ukc's Avatar
I did, I was just wondering, why for example 42r feeds from head?)))
Old Apr 1, 2010 | 06:49 AM
RyuEvoIX's Avatar
Factory frame turbos are journal bearing and require much more lubrication as apposed to ballbearing turbos. FP discovered through testing that the larger stock frame turbos are creating enough g-force to cause a spiking drop in oil pressure to damage the turbo if fed from the head.
Old Apr 1, 2010 | 08:36 AM
iTune's Avatar
^that.
Follow FP's instruction to a tee. They know how to route and install the oil-lines through lots of R&D and lots of failures using the head as a oil pressure source.
