how does your water pump feel?
Old Apr 12, 2010 | 06:14 PM
oneofakindracer's Avatar
im doing my timing belt (45k on the od) and im debating changing the water pump. it has no shaft play but if i turn it extremely slow i feel a slight jerkyness to it. is this normal for this pump or should i replace it? all the other cars water pumps ive changed were free spinning, this 1 has some resistance. thanks in advance for the help.
Old Apr 12, 2010 | 06:18 PM
Minion's Avatar
i wouldn't give it the benifit of a doubt. get a new one!
Old Apr 12, 2010 | 06:37 PM
AngryEvo8's Avatar
Agreed Mine went out at only 43k So who knows yours could go after you hit 46k. Just do it all at once it will be easier for you.
Old Apr 12, 2010 | 06:38 PM
i know but id hate to change it if its still good, money is tight right now for the next few months
by jerky i mean its almost like pulling your finger across a glass table when it makes the squeeky sound minus the sound and much less resistance. if that made any sense.
Old Apr 12, 2010 | 08:54 PM
biggie5252's Avatar
That's a good sign of bearings beginning to wear out.
Old Apr 12, 2010 | 09:04 PM
WHTEVO's Avatar
Change it. Would you rather to your timing belt job twice?
Aaron
Old Apr 13, 2010 | 07:15 AM
barneyb's Avatar
You may have the one that came off of my car at 60K. It feels like new and has a double your money back warranty. No gasket.
Old Apr 13, 2010 | 10:06 AM
thanks guys i guess ill hafta swap it out
Old Apr 13, 2010 | 10:09 AM
project_skyline's Avatar
I didn't change mine at 60k and its still working great at 91k miles. Haha. I can do a timing belt job in 2 hours or less though.
Old Apr 13, 2010 | 11:35 AM
20gmr's Avatar
They have some spinning resistance because of the seal. Mine is still going strong at 67k. My local mitsu dealer doesn't even replace them when customers come in for a 60k service. IMO its not timing belt driven so if it fails it won't instantly cost you an engine. Only way it would really do damage is if you ignore the temp gauge.
Old Apr 13, 2010 | 06:27 PM
it does feel as if its rubbing against a seal hmm now im perplexed. i know they are supposed to be changed at 120k but im still worried....its only gotta last 2 more years if that.
Old Apr 13, 2010 | 07:43 PM
evodude32's Avatar
Every brand new evo water pump I have installed they always feel a little "rubbery" when turning them. They sure don't spin freely. Sounds fairly normal to me.
Old Apr 13, 2010 | 11:43 PM
prchico19's Avatar
I'd say change it now if you're worried about it and/or don't want to pull it all back apart just to replace it when it does go bad.
Old Apr 14, 2010 | 07:19 AM
biggie5252's Avatar
I don't know if the water pump has ball bearings in it or not, but "catching" is a common sign of ball bearings wearing out. Even new ball bearings don't spin very easily. The pump should turn smooth with some friction (the seal). There shouldn't be any catching like you described.
danike
Aug 6, 2014 08:08 AM
Drifto
60
Jun 13, 2014 09:48 PM
aggieEVO
Feb 12, 2014 01:34 PM
WORD
Dec 3, 2010 07:51 AM
evoryne
Jan 30, 2008 12:09 PM
