bigger intercooler???
No, what? You state that there is not enough airflow through "those" intercoolers? Are you meaning that the BBK's compressor doesn't move enough air to fully take advantage of a larger than stock IC, so that upgrading from stock, would be senseless, or that there is too much of a pressure drop across the ETS IC with the 3.8" Garrett core.
A lot of people swear by the Garrett 3.8" Garrett core used in both the ETS IC and the Buschur Racing Race IC. These IC's have been proven time and time again to be extremely efficient and are well suited to all of the stock framed turbos on the market.
When dealing with turbos and intercoolers...colder is better.
We have used our 4.0" intercooler on several 800hp+ applications as well. This customer doesn't plan on upgrading past the BBK, so he can get away with a good 3.0" intercooler or 3.5" if he thinks he might upgrade in the future or wants to run high boost on the BBK.
Thanks!
Michael
Thanks!
Michael
Thanks!
Michael
Thanks!
Michael
good info!
Thanks!
Michael
Thanks!
Michael
I made 409whp on a mustang dyno using a stock Evo VIII intercooler. I wasn't even pushing a lot of boost (25psi), I could have done much much more power but I had stock internals. The stock Evo intercooler can push much more. If I was you I would push a little more and see if the car will trap significantly higher before you do the upgraded intercooler.
Carlos
Carlos
Carlos
Carlos
Thanks!!
Michael
i run a bbk with a garret 3.8 core and saw improvements when i switched to it from a smaller intercooler. i do run pretty high boost, 27.8 psi but the intercooler is what makes that safe and the numbers consistent. i was not able to get to 400 on a mustang dyno till i changed to the 3.8 garret core. take it for what its worth and run the garret core.
jeff
jeff
I only consider gains when I can see higher trap speeds and lower ETs. As far is the dynoi, well it is very subjective, I am not looking just at a peak gain hp number I am looking also at spool -up and how the power and torque is delivered.
You have no idea how much I(a guy that owned 18 turbo cars so far) hates turbolag. You can only talk to me into bigger intercoolers as long as they provide a good balnace of spool-up,more HP,more torque,better cooling, better acceleration, better traps.
I still keep the car magazines in which some intercoolers were added to even Evos with 1hp gain and in other cars with hp loses.
For the most part once you get into a power level and the right mods you are mostlikely going to see gains when you are pushing significantly more air but I insist and affirm that the stock intercooler can do far more that what you might need.
I always use my own example becaause I am my own guinea pig but my 2g DSM trapped almost 120mph in the summer at 3100ft, this equals to 124mph at sea level(just go to NHRA altitude conversion chart and look at it). but like I mentioned earlier(a couple of post before) I wasn't pushing it, I was limited by the stock 7 bolt "crank walker" stock unmolested engine(94500miles).
To make my history short, I could prove you that the stock intercooler can do /will do suficiently well to support 125mph traps anyday of the week(with the proper mods at sea level).
If it wasn't because I am enjoying the stock turbo on e-85 so much as we speak I would be already opening one of my classic post in which I am testing the HTA Green witrh stock IC. I have the HTA green(had it for a while) but is not installed yet. I will absolutely share my new dyno numbers and track numbers(no plans on upgrading the intercooler by the way).
Carlos
Carlos
i switched from the 3.5 ets core to a cbrd garret core and had success, ill leave it at that.
jeff
My .02 is get the intercooler that will allow for more timing, prevent heatsoak and cool the hotair from the turbo. As far as being a dyno queen and getting 2 more hp or 8whp more, I don't think that alone can warrant another ic. If it performs the above functions then it has served its purpose well and also pricepoint.
You want it black (and I agree, it looks slick), you get the thing Anodized black, it put's a layer of Aluminum Oxide on the aluminum, then dies that layer black. It's .001" thick, and has virtually no impact on the intercooler's ability to transfer heat.
