Can a T3 6262 BB turbo kit be put together for $3000
Subscribe
Apr 21, 2010 | 09:04 PM
Back to the drawing board, I'm looking at the Buschur Cast FS635 kit. I've also talked to Mike @ AWD about build a kit, using their manifold, 6262 BB, Tial 44mm Wastegate, with custom DP and oil lines. Any other ideas?
Reply 0
Apr 21, 2010 | 09:17 PM
You can build an ETS T3 turbo kit for under 3 grand with a 6262 billet journal bearings.
That or look into BW turbos.
Reply 0
Apr 21, 2010 | 09:29 PM
If you piece it together yourself, you can probably do it for 3k. Just keep an eye on the For Sale section.
Reply 0
Apr 21, 2010 | 11:43 PM
Quote: You can build an ETS T3 turbo kit for under 3 grand with a 6262 billet journal bearings.
Journal bearing wont take abuse, ETS offers the BB 6262 with everything you need for under 3500 still great deal.
Reply 0
Apr 22, 2010 | 08:16 AM
We beat on the journal bearings with our supra turbo kits and they seem to work out pretty good If you can afford it though, the extra money for the ball bearing setup is worth the price!
The ball bearing turbo gives you a better transient response between gears and allows you to hold more boost between shifts over the journal bearing setup.
Either way we have you covered for a good price
Thanks!
Michael
Reply 0
Apr 25, 2010 | 10:52 AM
-TFab 304 Stainless V-band manifold
-Precision 6262 BB turbo w/.82 turbine
-3" SS v-band downpipe w/bungs
-2.5" Aluminum lower charge pipe
-Oil feed/return
-44mm Tial/Precision wastegate w/dump tube
Total with shipping: $3,150
http://tab-fabrication.com/Gallery/P...l_35r_Kit.html
Reply 0
Subscribe
