fuel pump harness - wiring question
Old May 1, 2010 | 07:53 AM
yuronich_b's Avatar
On the fuel pump harness that runs between the assembly and the pump...my wires pulled out on the end that only has two wires (the end that plugs into the assembly).
My question is, which wire goes in which spot? The gray plug on that end of the harness has a clip on one side of it for reference...
A pinout for the plug on top of the fuel pump would work to answer this as well...
Thanks
