EVO VII exhaust vs EVO VIII
Old May 1, 2010 | 04:30 PM
gveranda's Avatar
Lightbulb EVO VII exhaust vs EVO VIII
Can you please advise me whether i can use the 8 turbo back on 7??as all the ones on ebay says 8 .I'm expecting to buy a off shell one or can I modify my standard one to be able to handle ~400hp as im expecting to buy a FP RED very soon.
Every single advise is appreciated.Tahnk you
Old May 1, 2010 | 05:46 PM
kiley_sean's Avatar
Yes, it will fit, but it will be about 2-3" too long, though.
I had an Evo VII catback on my VIII, and it was short. I still rocked it because it was hidden behind the bumper. In your case, you can either leave it sticking out like a stinger, or you can get a couple of inches chopped out in front of the muffler and have it welded back together.
Old May 1, 2010 | 07:45 PM
gveranda's Avatar
Thank you for the quick response,will go ahead with a EVO VIII one then
Old May 1, 2010 | 09:05 PM
kiley_sean's Avatar
I just noticed that you said "turbo-back". I can't vouch for the downpipe or test pipe. Only that I had an Evo VII cat-back on my VIII. Those two pieces "should" be the same as I don't think there was much difference upfront between the VII's and VIIIs (pre-'05/ACD).
I hope it works out for you.
Old May 1, 2010 | 09:14 PM
gveranda's Avatar
gonna give it go if doesnt if will sell the downpipe on ebay.will let everyone know once Ive tried that.Thanks again
Old May 2, 2010 | 10:03 AM
8000rpm's Avatar
If your Evo VII has an RS style rear diff ( non AYC ) like the USDM cars it will be fine , but if the EVO has an AYC diff the exhaust from an VIII whitout AYC will not clear the AYC pump on the rear of the car.
Old May 4, 2010 | 05:49 PM
gveranda's Avatar
Thanks everyone its more likely spending some more money after buying EVO 8 9 exhaust, It is cheaper to buy a EVO VII exhaust spending bit more than buying a cheaper EVO 8 9 and working it out to match evo 7.
Thanks for all updates
MrFreddieA
Apr 10, 2015 09:45 AM
xmel012
Nov 28, 2012 09:13 AM
Evo1001
27
Jan 16, 2012 11:52 AM
Phoenix*
Dec 2, 2011 05:16 AM
Hong Kong Evo
Apr 2, 2004 04:37 PM
