help! boost keep increasing after 5k+ rpm
Old May 3, 2010 | 11:39 PM
feimax's Avatar
Hey guys im having a weird problem.... my boost is suppose to hold 1.3bar but wat happens is it will peak to 1.3 bar then tapers down to 1.1 then after 5k+ rpm it will just keep going to 1.5, 1.6 so on... and when im on high boost which suppose to hold at 1.5bar when around 5~6k it will hit 2.25bar... im on a fp green turbo with uprated actuator if im correct its a 1.7bar actuator... i've checked the actuator and changed the silicon lines to the boost controller...
Old May 3, 2010 | 11:51 PM
Chris Moore's Avatar
Loosen your wastegate actuator arm. Boost is most likely creeping and this is the easiest way to resolve it, you may sacrifice some spool so only loosen as far as is needed.
Chris
Old May 4, 2010 | 12:15 AM
feimax's Avatar
isit even possible to adjust the actuator???
