Mikey's LR2.4 MIVEC 10:1 Motor Build
with the right tuner you will crack 500 at 28psi no prob on 93 with your car. 500 is your goal right? 500 would be a safe power range for your car and it would last a very long time at that power level. it would certainly get you your 10 second pass with proper driving
I've been hearing complaints about the egt's being high with the smaller turbine housing on stock frame. I hope there is a work around. If not, I may have to go 3586 and shatter the bank.
What numbers did this do on dyno? the firewall at work blocks pictures
560whp/506 ft-lbs
I don't know any birdies, but I'd guess timing was 0 degrees at peak torque, 13-14 degrees out the top and 28 psi of boostz.
Looks like fun so far.
Mikey, you said don't say anything on the forums, so I didn't. I thought you were telling certain people privately (at least it seemed like a lot of people knew). Now if da Rock can keep it in his pants for a while longer!
Awesome numbers dude! Crazy thats not even all out yet, I can not waittttt till my car gets done now. Especially with those baby cams in. Just absolutely sick.
Rock Im doing 93+meth.
I'll see if we can get some dyno runs in with no meth spraying for just 93 pump numbers alone.
When I hit Idaho I mash the pedal and don't let up. It's only ~70miles where I cross so I can usually make it without causing a stir!
93?! I wish we had 93. We have 92 that stinks suspiciously of 91! And I thought I said you "don't know?!" Gettin' me in trouble!
Mikey
No prob, I'd like to see the difference myself on how much more I can get out of it by adding in the meth/water combo. Id rather run straight M1, but I wanna keep the pump happier.
Mikey
