Unique Overheating issue
Old May 11, 2010 | 02:53 PM
rcgoff2's Avatar
Ok so i tried searching and couldn't find anyone who has had this same issue. 3 days ago i noticed the car overheating on the highway. Scared the living crap out of me, and so i pulled over turned the car off and it cooled and was fine. Now every morning and afternoon to and from work, as soon as i get on the highway, the car comes to temp(just under half way mark), then it will go up to 3/4 way no matter how easy i am on the car. Then, it drops back to slightly less than half(normal) after 20-30 seconds. I can then literally beet the crap out of the car and it wont happen again. It usually takes a couple hours for the car to cool completely before i can get this process to repeat. So like i said the car heats up normal, then goes to about 3/4 mark, then drops to normal after about 20 - 30 seconds after being hot. Is there air in the lines>? Any help would be greatly appreciated.
-Ryan
Old May 11, 2010 | 03:02 PM
kwanza's Avatar
Maybe the thermostat is going out..
Old May 11, 2010 | 03:14 PM
jdmeg6's Avatar
Was just going to say sounds like the thermostat is starting to go. If so its a cheap fix. Thank God for all the blessings no matter how small!
Old May 11, 2010 | 03:16 PM
rcgoff2's Avatar
sounds good, does anyone know if mitsu usually carries them on hand? I just ran to autozone and they were out! Also, i dont wanna sound like an idiot, btu can you buy coolant premixed at th 50:50 ratio like it says to use in the manual? And if so what kind would anyone suggest? Thanks once agin for the help!
Old May 11, 2010 | 04:03 PM
YogSaahoth's Avatar
Veteran: Army
they may not have one in stock for u, but mitsu is the best place to get one. 50/50 will be fine in ur radiator..some evo owners adjust the ratio but if u have sub-freezing temp winters, which im sure u do, stick to 50/50. i use prestone coolant in all my vehicles and always works great
Old May 11, 2010 | 04:41 PM
SLO-EVO's Avatar
Prestone sells pre-mixed anti-freeze. I would speculate the thermosthat to be your first culprit. Check your coolant level as well. If you dont have coolant, there is your issue.
