Car falling on face when accelerating
Old May 12, 2010 | 03:19 PM
sktng22's Avatar
ok so whenever i start my car after not being in it for a couple hours or more and let it warm up completely it falls on its face every gear when i hit boost. when i first accelerate in every gear it feels almost as if the wastegate dosnt open or its not getting fuel? but the second time or any time after i accelerate and hit boost in any gear the car works fine??
Old May 12, 2010 | 08:03 PM
bbyevo8u's Avatar
heat soak or boost leak.. prob
Old May 12, 2010 | 08:24 PM
sktng22's Avatar
i thought of a boost leak but if it was a boost leak it wouldnt work fine after i went through the gear once it would still leak. and heat soak. this is when i first start the car and start driving
Old May 12, 2010 | 08:32 PM
jy951's Avatar
Fpr?
Old May 12, 2010 | 08:36 PM
eponti's Avatar
Might be knocking and pulling timing.Mod list?
Old May 13, 2010 | 08:21 AM
sktng22's Avatar
Injen upper and lower intercooler pipes
ams front mount
full 3 inch exhaust
255 fuel pump
MR diverter valve
this problem just started happening outa nowere. well i actually noticed it happening the day after i first started my car without letting it warmup and took off in every gear about 2 weeks ago
Old May 13, 2010 | 08:41 AM
EriCS's Avatar
ams front mount
full 3 inch exhaust
255 fuel pump
MR diverter valve
Sounds like you treat your car well, I wonder why its doing this???
Old May 13, 2010 | 08:45 AM
DraheimEvo8's Avatar
prob a boost leek. try a leakdown test
Old May 13, 2010 | 09:37 AM
Toxin's Avatar
I wouldn't call this out of nowhere and it's very likely that you already answered your own question. Stupidity like that can cost.
Old May 13, 2010 | 09:47 AM
project_skyline's Avatar
+1
Boost on a cold motor is a bad no no.
Anyway check all your vacuum lines especially your fuel pressure regulator line.
Then do a boost leak test.
Old May 13, 2010 | 09:52 AM
mdsevo06's Avatar
Do you have a AFR Guage and what are you reading when it falls on it's face?
Old May 13, 2010 | 11:13 AM
evozmarine's Avatar
yeah mine did this b/c of the fpr vacuum line...found it doing a boost leak check..plus i found another small leak
Old May 13, 2010 | 11:18 AM
20gmr's Avatar
do you a stock airbox? sounds exactly like leaving the clips out of the snorkel on the factory airbox.
Old May 13, 2010 | 09:50 PM
sktng22's Avatar
nah its an injen filter at the end stock airbox is gone. and no i dont have an AFR gauge but i will be doing a boost leak test soon i guess and buying an AFR guage soon because im sure that would show alot of whats going on.
Old May 13, 2010 | 09:52 PM
sktng22's Avatar
The reason i didnt get an AFR guage yet was because someone told me it dosnt work with the stock ecu?? dosnt the AEM AFR kit have a computer or some brain of its own that dosnt even connect to the stock ecu or what?
