smoking blue.. help please
hi, i have evo ix 06 mr, 35k miles
first! i see the blue smoke on muffler when i start the car..
looks like after warmed up, i dont see the smoke anymore, then
after i run the car for few minutes, i see the smoke again.. blue..
then i found the oil leak on the exhaust maniford, not dripping but its slightly wet..
fp red, 1.1 head gasket, head studs, 27boost...
any guess..? i just found the problem today.. thank you..
First check for shaft play. Inspect the turbine and compressor for oil. Open it up if you have to;
http://www.vfaq.com/mods/Turbo-rebuild.html
To the original poster;
Is this happening worse under boost?
http://www.dsmtuners.com/forums/newb...ns-smooth.html
