timing issues under load
Old May 26, 2010 | 09:31 PM
sharkm87's Avatar
....wierd issue started today..
doin some logs, can't seem to get the boost set right with the gm 3 port...sometimes its 18lbs...other times it goes 26 than down to 18 back up again..and very sporatic...
so i did a boost leak test, and i had a hose off on egr...put that on and zip tied it..no more leaks anywhere..tested again
bost was very jump, i did remove any correction factors...even if setting wgdc to 100...it will want to boost to 18/19 and stay there..sometimes it will jump in 20's it has hit 27 than goes right back to 20...
for that. i will try my mbc to see if its my 3 port..but after thihs a wierd issue started happening ..i started noticing like 30counts of knock, i look at my timing under load and as soon as i get on gas, timing is showing 20 degrees.....definately is set in the 1- 10 in timing map...the timin issue just started out of no where...
tried reflashing map...still timing is very high for some reason....plugs look fine
Old May 27, 2010 | 06:10 AM
sharkm87's Avatar
bump stop bump
