bad ecu? bad coils??
Old May 27, 2010 | 12:49 PM
sharkm87's Avatar
been searching all day and can't find nothing....
current issue if i blip the gas timing shows 50 degrees constant...if i attempt to boost..timing will never go into the single digits..how normally for instance at peak you see 3 than it goes up to 12 or whatever
it used to do that yesterday...but now timing will be in 20's to high 20's knock counts sky rocket...
now I was in process of re tuning yesterday, and during a flash i did get an error in ecuflash...but it said re try as i did and it flashed succesful...
if i read map from ecu it pulls it fine and its the proper one...however
this issue...could it be my ecu?? or coils?? wires?? i couldn't find what are the symptons of bad coils...the car does start up and seem to idle fine until i give it gas. timing gets psychotic
IDC seems to be fine, numbers are consistant with how it always ran
any hepl appreciated
