No crank...
Old May 30, 2010 | 10:22 PM
Hoaxanie's Avatar
No crank...
Recently my car been acting up...When I turn the key I get nothing not even crank...I till have power because my dome lights still work and even my headlights will turn on...but I dunno y I get no power to the engine I try to jump start and nothing. I check all the fuses and connections and nothing it wasn't till I pop off the ECU fuse and put it back on and it started after that....but now it will turn off while I'm driving on the road it would just shut off in the middle of the road luckily I have had enough speed to merge over and do the same processes until I get it to turn on again...I dont get a check engine light either....I dunno if my starter is starting to give out...has anyone experience this before...I need to fix this issue asap...
Old May 30, 2010 | 10:33 PM
goldenEvo's Avatar
I think you have a relay going out. Will try to find out tomorrow or Tuesday.
