exedy stage 2 clutch question!!!!
Old May 31, 2010 | 06:26 PM
Evoleader88's Avatar
everytime i shift at high RPM round 7k- 7200, its really hard to shift to nex gear. like it locked or sumthing. and it makes me miss my gear everytime try to shift fast. its annoying, wat could be the problem?
Old May 31, 2010 | 06:41 PM
any adviser!?!?!
Old May 31, 2010 | 08:17 PM
any body know what the problem?
Old May 31, 2010 | 08:37 PM
toxic-evo's Avatar
have u tried adjusting your clutch pedal?
Old May 31, 2010 | 08:38 PM
toxic-evo's Avatar
and do a search there are many about high rpm lockout dealing w clutches, my stage 2 works fine other then a bit of chatter
Old May 31, 2010 | 08:42 PM
evo unknown's Avatar
What clutch kit do you have exactly?
At high rpms and hard shifting multi plate clutches can have problems where the clip pops out.
Look into this..http://www.streettunedmotorsports.co..._fork_stop.htm
Old May 31, 2010 | 08:45 PM
toxic-evo's Avatar
i thought stage 2 only came in 4 puck and 6 puck designs?
Old May 31, 2010 | 08:54 PM
how do u adjust the clutch pedal?
Old May 31, 2010 | 09:17 PM
if i install under hood shifter bushing will that help?
Old Jun 1, 2010 | 08:25 AM
toxic-evo's Avatar
use the search button lol, otherwise just get under your dash and look. there is a threaded rob w a nut on it that moves your pedal up and down
Old Jun 1, 2010 | 03:02 PM
so should i move it up or down
Old Jun 1, 2010 | 03:07 PM
italianevo88's Avatar
Yeah ive gotten that, its like the trans is fighting against you to not shift. Im also interested in the answer to this- unless its just clutch pedal adjustment
Old Jun 1, 2010 | 08:45 PM
i just adjust my clutch but cant test it out yet. cuz 12 am now. i will test it tom after work and post the result.
Old Jun 2, 2010 | 07:33 PM
alrite, just took my car out for a spin. drove it hard and shifted at 7000 rpm, gear went right in 1st 2nd n 3rd even 4th. no missing gear or anything
OVERALL: Who ever have this problem should deff adjust ur clutch pedal. Especially right after u upgraded ur clutch.
this helps me alots. hope itll help u guyz too
