Torque Solution bolts?
Old Jun 6, 2010 | 09:33 AM
Ekoy's Avatar
I bought the 4pc torque solution motor mount kit and the kit came with 4 bolts. Anyone that has bought this kit, could you tell me what these bolts are for?
Im about to install them and I cannot find any install instructions for the bolts.
Old Jun 6, 2010 | 09:40 AM
binky's Avatar
The bolts are used to attach the transmission to the transmission motor mount.
You have to take the studs out of the transmission and use the bolts instead because the studs are to short.
Easiest way to get the studs out is to double nut them.
-Bink
Old Jun 6, 2010 | 09:55 AM
Ekoy's Avatar
Thanks alot! That makes sense
Old Jun 6, 2010 | 09:56 AM
Ekoy's Avatar
Is the spacer used for the Trans mount aswell? I figured since 2 bolts have about an inch of no threads
Old Jun 6, 2010 | 04:46 PM
binky's Avatar
Yes sir. After you pull the studs out the spacer is used on the transmission mount closer to the firewall.
You'll see how it fits together once you get into it.
-Bink
