Bad wastegate?
Old Jun 7, 2010 | 05:58 PM
k20turbo's Avatar
Bad wastegate?
I am trying to figure out what is going on with my car. I have the hallman manual boost controller and it has been working great holding 25psi with some drop by redline for the past 6 months, a few days ago the car felt slower and like the turbo was not spooling as fast as normal so I got a data log and saw it was only getting 17 psi so I did the following tests...
Turned the boost controller all the way down and got 10 psi
Hooked the wastegate up to a vacuum source without the boost controller got 10 psi
Turned the boost controller all the way up and got 17
Unplugged the wastegate and got 17psi
Boost leak test and did not find anything
Swapped bov's and same thing
Last thing it could be is the wastegate right or what are the symptoms of a turbo that is going bad?
Oh yeah stock evo 9 turbo and wg
Old Jun 7, 2010 | 08:37 PM
sparky's Avatar
You need to establish whether or not your WG is functioning properly. Disconnect and plug the lines to the MBC. Run a length of vacuum hose directly from the compressor housing discharge nipple to your WGA. Now, raise boost by turning the turnbuckle inward. This way you'll find out if your WGA is functioning properly or not. If boost increases and holds...then the actuator is OK.
plokivos
84
Jun 7, 2017 11:25 AM
ghad
May 25, 2014 02:27 AM
elhalisf
36
Nov 19, 2012 02:06 PM
CrawlinTBSS
12
Sep 29, 2011 05:42 PM
StevenStarke
15
Dec 3, 2008 12:28 PM
