info on springs and retainers..
wats up guys.. got a quick question.. did a search but couldnt find my answer.. i just installed my new setup in my evo.. and running a t67.. i got kelford 272's and looking to raise my revs to 9k or near it... right now im at 7995.. im in the process of buying my arp head studs and wanted to upgrade my head a bit.. do u think if i toss in the gsc beehive springs and keep stock retainers ill be ok to rev to 9k.. i rarely push the car that far so its not like ill be beating on it.. just for safety.. i know alot of people probably recommend the retainers too.. but will she be ok wit just upgraded springs at 9k.. thanks alot any info would be great..
on maperformance they have a set of gsc springs for 215 and they say 9k.. ive read a few people mention that the stock retainers r good.. im not looking to be revving sum crazy numbers lol.. just wana be save..
any feedback would be helpful.. just wana know if its save or not.. i mean i know there is alot of people here wit sum crazy setups and lots of knowledge on this stuff.. thanks
Wait a second. Is your motor built? If not, I would not suggest reving your car that high as you will probably hang a rod out of the block.
To answer your question, Reving to 9k is different depending on what cams you have in the car. With the Kelford 272's I would suggest a dual spring and retainer kit. These cams are a bit more aggressive then most.
-Em
-Em
yea internals r stock.. thanks for all the feedback guys.. i just wanted to make sure casue im on stock spring and retainers.. and i know i shouldnt be trusting them anyways wit the cams i got.. but just wanted to see if it was possible to rev that high.. but if its a risk of blowing sumthing up no thats ill stay at 8k lol.. thanks again
i know where u coming from.. i got a t67 wit a 63 ar.. i hit full boost around the 5500 area so im just seeing if i can get that extra rev out of her.. i mean i like where she is now and between shifts holds luvly.. i luv the turbo and how its running but just wana see if its safe to bring here up a little more than wat im revving at wich is 7995..
