Newb question about upping my boost...
Old Jun 15, 2010 | 08:04 PM
evo1981's Avatar
Ok I've got an 03 evo 8, bone stock minus a fujita intake, with upper an lower intercooler piping. Anyhow I'm only running 16 pounds of boost, I read there supposed to be around 17-19 stock correct?? Well I'm about to install a halmann boost controller, and I was wondering with the factory fuel mapping would I be ok to set the boost to 19- 21 pounds or so with no tune?? I'm planning on taking it to English racing here in a few weeks hopefully for the tune but was curious as to the info you guys have.Any answers would be greatly appreciated
Old Jun 15, 2010 | 08:23 PM
xmaciek82x's Avatar
Factory map is very rich so you "should" be good until you go and get a real tune.
BTW its been 4 years since my evo seen stock boost so I have no idea what stock boost is. 16 psi seems kinda low. Is that at redline or at peek boost? You might have a boost leak after installing the UICP and LICP. I would to a boost leak test first.
Old Jun 15, 2010 | 08:25 PM
Craig King's Avatar
There are a couple reasons why you could only see 16psi. Since you have an 03, you also have the plastic divertor valve which is known to leak. Another possibility is a boost leak somewhere since you have upgraded IC pipes. If you're going to install a MBC, I would highly recommend a tune and a boost leak test. There are a couple gaskets in the throttle body that are also known to leak - I know mine did.
But definitely do a tune with the MBC.
Old Jun 15, 2010 | 09:32 PM
evo1981's Avatar
Awesome thanks guys, I was thinking I might have a boost leak, it runs very smooth and it peaks at 16 pounds, I will do a boost pressure test
