Bad boost leak help
Old Jun 17, 2010 | 08:23 AM
Nastynine's Avatar
Bad boost leak help
fixedddddd
Old Jun 17, 2010 | 10:12 AM
Nastynine's Avatar
no one????
Old Jun 17, 2010 | 10:47 AM
Evoryder's Avatar
Boost leak test.
Old Jun 17, 2010 | 12:04 PM
Nastynine's Avatar
no boost leaks, car runs fine, afr's are good, i feel like something is stopping the turbo from hitting boost, it feels as if the wastgate is stuck open or something, but when i push the wastegate it moves fine,
i also installed new iridium plugs, and a walbro 255lph. i was supposed to get a tune today but idn't feel comfortable driving to the shop like this. could the fuel pump be causing this?
Old Jun 17, 2010 | 12:44 PM
Nastynine's Avatar
this forum fu*king sucks. no one is any bit help
Old Jun 17, 2010 | 12:54 PM
Nastynine's Avatar
you all suck
Old Jun 17, 2010 | 01:20 PM
SavEVOIX's Avatar
Originally Posted by Evoryder
Boost leak test.
how about you try this?
Check all hoses and make sure you have your BCS plugged in correctly.
Old Jun 17, 2010 | 01:22 PM
xmaciek82x's Avatar
Originally Posted by Nastynine
you all suck
^ yea good luck with your car then.
Old Jun 17, 2010 | 01:36 PM
sharkm87's Avatar
you have to realize OP. that people work....you post today..and you want replies yesterday....
it dont work that way.
...so you pulled out the turbo, and now u wont hit boost...like someone said did you check the BCS and make sure you didn't flip flop the cables.
how much boost is the car buliding.
Old Jun 17, 2010 | 01:45 PM
SilverShadow03's Avatar
Double check everything you did. Take your time and go through the intercooler pipes, vacuum lines, etc...Are you throwing any codes? Intake on correctly?
Ease up on the attitude as well...you'll get a lot farther with a cup of sugar than a cup of vinegar. But, by the sounds of it, you already know this.
Good luck.
Old Jun 17, 2010 | 01:49 PM
EvoDan2004's Avatar
wow. what a d bag.
1.pull the intake off. check the compressor wheel. make sure it spins.
2.do a boost leak test.
do not report back until the above is complete
Old Jun 17, 2010 | 01:52 PM
EvoDan2004's Avatar
ahd replaced the exhaust manifold gasket to the heads.
is it a v8????
Old Jun 17, 2010 | 01:54 PM
19DB794's Avatar
Lol at replying every ~30 minutes expecting responses. Double check your work.
Old Jun 17, 2010 | 01:56 PM
leonevox's Avatar
watch your language buddy. This kind of attitude would do u no good.
Old Jun 17, 2010 | 02:24 PM
chaotichoax's Avatar
no one helps?
you have 10+ replies with a variety of solutions
as someone else mentioned, it's 12 in the afternoon most people work and aren't available at a minute to minute time period
honestly, I'm surprised anyone is giving you advice after that
