Front LSD
Old Nov 23, 2003 | 10:02 PM
MP5's Avatar
MP5
In Timeout
Originally posted by jwfisher
Elise? An orange to the EVO Apple. For a different kind of enthusiast entirely.
Just a suggestion you wouldnt want to throw it around the track?
Old Nov 23, 2003 | 10:08 PM
jwfisher's Avatar
Of course I would... being a former S2000 owner the Elise would be near the top of my list to try. I would hope we get several at the track once they finally start to flow...
Old Nov 24, 2003 | 03:00 PM
SILVER SURFER's Avatar
The Kaaz front LSD works and fits BUT you have to use the rear dif as well. For some reason if you install front LSD only the center dif no longer functions as normal. Strange but true.
I was looking into this optoin as well, but I was told it is the center diff that has to be replaced if you use there limited slip front. This seems to make more sense yes?
They said that the front diff cannot be used with the viscous coupling unit, that is why the center diff has to be replaced also.
Old Nov 24, 2003 | 09:41 PM
jwfisher's Avatar
I'm not sure I believe this for swapping in a stock EVO VII front LSD. It may be a different story for the Katz.
Old Nov 24, 2003 | 09:47 PM
MP5's Avatar
MP5
In Timeout
Correct the kazz you will need to change the center No confirmed reports on any changes to the center of the RS (not the EVO VII that wont fit!)
