please help new exedy tripple car wont go into gear when running
I need some help badly guys please... I just got done building and install my new motor and i got a exedy tripple cerametalic and when the engine is running and at idle the car will not go into while it is running i have bled the clutch system there is no more air in it. also i have adjusted the pedal in and out both directions and still it wants to stall when i try to put it in gear....
I know the clutch is disengauging somewhat because i can hear the chatter of the plates i am really stuck i have done so many evo clutches and this is the first time it has dont this but then again this is my first exedy tripple installation...
is there anything else i can do without taking the trans back off i am going to take another stab at it again tomorrow morning so any input would be very appreciated. oh yea the motor is doing excellent so far oil pressure is great and sounds awesome more of that will come thanks guys in advance please respond to this if you have any clue what it is.
Seems to me your clutch is not adjusted properly. I would double check the adjustment and try it at different points and also make sure it is all bled out. If it's going into gear while the car is off, then you know it's clutch related. Good luck.
Aaron
Aaron
Did you align all the plates and the last ring up correctly? All the floaters are painted tho line up with the studs on the flywheel and the last ring on out trans side floater has to be turned a certain way.
TwStDeVo
Oct 20, 2015 03:46 PM
evotris
Automotosports - Illinois
Nov 29, 2012 06:13 AM
MRfabolous
Jun 23, 2010 06:51 PM
MRfabolous
May 15, 2010 10:40 PM
