started
Old Jun 25, 2010 | 01:06 PM
travail's Avatar
started
Well I found out that I have to put in new main bearing so out came the motor and the tran. But now I can clean up the engine bay and so on. I
Well I started to clean up the engine bay
and then I found this. I was llike WTF this is why you never drill a hole in the firewall with looking first.
The motor and tran coming apart
and then the main bearing.
Took the motor and tran apart tonight. The in side of the tran was very dirty.
Looks like there are little crack in the pressure plate
Then I saw this some one welded on the pressure plate
Clutch look like it was starting to go bad and I plan on getting a ACT HD STREET 6 CLUTCH it's good for 508 ft/lbs
at lest the fly wheel look ok but I plan on getting a FIDANZA fly wheel
