Anyone ever experience this after installing o2 dump?
Old Jun 26, 2010 | 12:18 AM
Nastynine's Avatar
[VIDEO INSIDE]Anyone ever experience this after installing o2 dump?
PHEWF it was a tune! thank godddddddd!!! lol thanks for your help guys problems all taken care of now
Old Jun 26, 2010 | 12:25 AM
EvolutinIX's Avatar
Sounds like it does not have anything to do with the O2 dump. If it felt strong before you installed everything then I hate to say it but it is probably something you did wrong or missed. Of the parts listed above I would check the LICP first. If your reading full boost(i assume you have a gauge of some sort) then your loosing it some where after the turbo. Check the pipe again and I bet you'll find something not right. Just my 0.02, good luck.
Old Jun 26, 2010 | 06:15 AM
bbyevo8u's Avatar
i think you need to do a boost leak check make sure all vac hoses are on then get it tuned!
Old Jun 26, 2010 | 08:52 AM
TJPhillips36's Avatar
Also could be the 255 is making it run pig rich and causing some pre-ignition problems. Also would check/replace the spark plugs. Do some maintenance (plugs, BLT, etc...) Then a tune asap!
Old Jun 26, 2010 | 11:58 AM
Nastynine's Avatar
i did change the plugs, and oil.
do u think this could be it? b.c the car did throw a "random cylinder misfire" code.? but i cleared it and it comes back once and a while and goes on its own without me clearing it
Old Jun 26, 2010 | 02:30 PM
Svendiesel's Avatar
Well I promise the waste gate's not "shutting" as you said during the pull...if that were the case, you'd be making more and more boost and the car may travel thru time
Old Jun 26, 2010 | 10:27 PM
Nastynine's Avatar
haha, well i know its not literally shutting, i just said that b/c the way it sounds. like u can hear the dump screeeeeeeaaaaming than it just gets quiet and looses power as if the wastegates closing u kno?
this is blowing my mind, im clueless. my turbo is in perfect condition idk what it could be
Old Jun 27, 2010 | 06:01 AM
scarface2jz's Avatar
Sounds like your ecu is pulling crazy timing to keep from blowing up cuz you have all those mods untuned
Old Jun 27, 2010 | 06:19 AM
cfdfireman1's Avatar
^^+1^^
You said in your first post "the boost gauge will read solid boost" so it's not a boost leak. I have to agree with scarface. How much boost are you seeing?
Old Jun 27, 2010 | 06:59 AM
Liqquid's Avatar
So you shouldn't be hearing the O2 dump screaming UNTIL the wastegate opens, but if you've got all those mods untuned you at least need to get an email flash... you've changed everything as far as how the air flows through the motor, how the maf reads.. chances are the O2 was just the "straw that broke the camels back" and pushed the ECU onto the low octane maps for protection.
I have heard it mentioned before that the O2 dump makes the wastegate open "easier" because there is no pressure behind it, but that's hearsay on my part, I have never installed one. Anyways what boost level are you trying to run?
Old Jun 27, 2010 | 11:04 AM
Nastynine's Avatar
right now the boost controller is cranked all the way down, its only pushing 17psi
the reason i've been holding off on my tune is b/c i dont want to go have my tuner go tune it and me have to pay him for him to tell me somethings f*cked u know?
i just wanna make sure this is a tuning problem, not a mechanical problem u know?
Old Jun 27, 2010 | 11:07 AM
Nastynine's Avatar
im gunna upload a video of this so you guys can see and determine better.
Old Jun 27, 2010 | 11:47 AM
Nastynine's Avatar
videos added!
Old Jun 27, 2010 | 12:06 PM
4xforce's Avatar
I have almost the exact same mods without a tune as well and I must say I believe it needs to be tuned. Since my mods were put on I have noticed more power under light to moderate throttle but seems like at times when I'm really ******* it, it acts just like yours. Do a boost leak test and get a tune and let us know how it turns out.
Old Jun 27, 2010 | 12:09 PM
Mellon Racing's Avatar
when you modify the engine, this can greatly improve the airflow and the ecu is going to go into a very weak area of the fuel and timing map in an attempt to keep you from blowing up the engine. This means way too much fuel and way too little timing in some cases and a very weak evo.
My advice get tuned http://www.mellontuning.com/index.ph...dex&cPath=1_28
