02 Dump Question
Old Jun 30, 2010 | 06:18 AM
rEVOlution04's Avatar
something is definitely wrong because it won't go into boost at all. The afrs drop to 10.0 then it cuts out... :-(
Old Jun 30, 2010 | 09:40 AM
xmaciek82x's Avatar
Looks like you did a lot of work at once. Start from basics, do a boost leak test. Using a wrong gasket on the o2 dump is bad but would not cause you to not go into boost. Check around the v-clamp between the hot side and compressor side of the turbo.
Old Jun 30, 2010 | 04:29 PM
After a very long stressful day and taking everything apart again I found the problem! A piece of built up carbon came off and get stuck so the flapper couldn't shut all the way...FML. Note to self check and recheck everything before install. So frustrating something so little can cripple the car, but I'm soooo glad it was an easy fix. Thanks everyone again for the help! It helped me so everything right and lead me to the wastegate..
Aaron
Old Jun 30, 2010 | 04:57 PM
Ludikraut's Avatar
Originally Posted by evoturbodreamz
... I'm going to have them use power tools to tighten everything down especially the downpipe and exhaust manifold just in case..
Manual torque wrench >>> power tools.
l8r)
