weirdest problem ever...
Old Jul 12, 2010 | 09:42 AM
ev0lution9's Avatar
I recently got tuned and installed FIC 950 injectors, bbk full, and a map o2 dump. now if i drive let the car sit about an hour or so it'll have a hard time starting about 5 or 6 cranks then it turns over and starts. originally i thought this was a cold start problem but if the car sits overnight it starts right up like normal..im at a loss, any suggestions?
Old Jul 12, 2010 | 09:47 AM
n2oiroc's Avatar
talk to your tuner. sounds like your map needs a little tweaking.
Old Jul 12, 2010 | 09:49 AM
ev0lution9's Avatar
talked to him the other day and he said that only one other evo has had that problem and he never found out what it was
Old Jul 12, 2010 | 10:00 AM
n2oiroc's Avatar
sounds like the cranking enrichment vs. coolant temp needs work. not sure how that works with the stock ecu, buts its an easy fix with a standalone.
Old Jul 12, 2010 | 10:09 AM
sphinxof2006's Avatar
I have the same problem with my e85 tune got to talk to my tuner too :/
Old Jul 12, 2010 | 11:52 AM
binh's Avatar
Originally Posted by n2oiroc
sounds like the cranking enrichment vs. Coolant temp needs work. Not sure how that works with the stock ecu, buts its an easy fix with a standalone.
+1
