LICP and turbo outlet ???
Old Jul 12, 2010 | 09:50 AM
RunThat's Avatar
I cannot seem to get a definitive answer on this, so I'll ask all of you. I am upgrading to the FP Black and would like to also order up the Race Pipe from them, which replaces the stock turbo outlet pipe. Does this pipe ONLY work with the Buschur LICP?? It sure seems to. I will be using the ETS 4" FMIC and LP2 LICP, so I believe I will have an issue. Is the Race Pipe even worth getting due to its larger (fatter) size, and if so, should I just cut it to the proper length? Or, should I just not bother? Some informative answers would be appreciated. Thanks!
Old Jul 12, 2010 | 09:54 AM
TJPhillips36's Avatar
Buschur's lower intercooler pipe typically replaces everything from the turbo outlet to the intercooler, ETS LICP connects to the stock outlet.
