Problem someone please help!
Old Jul 19, 2010 | 11:20 AM
andrewzaragoza's Avatar
if you are on mbc you may need to adjust it since it will boost lower because of the hot weather. also you should check you sparkplugs. if they are old replace them and put in the proper gap.
Old Jul 19, 2010 | 05:23 PM
korpzjuggalo's Avatar
It's ebc. Funny you say something about it because my buddy had mentioned the solenoid may be going bad or something. Going to have to check it all out. I did change the plugs and gapped back to what they were. Thanks for the help buddy!
Old Jul 20, 2010 | 03:21 AM
evo_q8's Avatar
if your throttle body is leaking, get the o rings from works or mil spec and have that done too while you're at it. Best of luck!
Old Jul 20, 2010 | 04:14 AM
evobullit2017's Avatar
Originally Posted by vmrevo9
have you done a boost leak check yet? sounds like maybe a bad coupler (a hole in a coupler)
[QUOTE=korpzjuggalo;8485085]I did a boost leak test and only a tiny bit of air coming from the throttle body, so going to replace that gasket tomorrow. QUOTE]
please read the thread before you reply
Old Jul 21, 2010 | 02:56 PM
Will do, thanks.
_Ryan_
Dec 19, 2014 01:54 PM
TOAjosh
May 22, 2012 04:55 PM
2StepsAhead
11
May 9, 2010 08:37 AM
mitchedout
Jul 1, 2009 07:21 PM
David Buschur
909
Jun 22, 2008 06:20 AM
