clutch squeak
Old Nov 19, 2003 | 07:34 AM
raywong's Avatar
clutch squeak
it started after I adjusted the pedal to make it higher, but I am not sure it is related. It squeaks only when I press the clutch all the way down, to the last 2 inch. The nosie seem to be coming from underneath. Could it be the master cylinder or something? Is it possible to apply some grease to it?
Old Nov 19, 2003 | 12:47 PM
timzcat's Avatar
Make sure that when you tightened the lock nut that it did not put a twist in the end that attaches to the pedal. Chances are it is rubbing the sides where the pin goes through the pedal arm.
To put it another way, the u-shaped end that has the pin to attach to the pedal arm may be twisted and the sides of the U are rubbing the pedal arm when the pedal fully depressed.
