Buyers remorse.. need help with air filter/intake
Old Jul 21, 2010 | 01:19 AM
  #46
jasnm21's Avatar
Originally Posted by Mautofied.IS300
Tuning WGDC is included with a tune, if not get a different tuner. To install it will take 15 minutes.
Who says he has an accurate way to measure boost (map sensor) to ensure he tunes his MBC properly as well?
What the OP should do is call whoever is going to tune his car from now on and get their opinion, and follow it. If they want MBC go with it, if they want a GM 3 port go with it.
-Will
Great advice. I also agree that a 3 port is the way to go, but I don't believe it is for everyone, although I recommend it to all of my friends.
Old Jul 21, 2010 | 05:50 AM
  #47
TeStUdO's Avatar
Originally Posted by BoostFTW05
jasnm21, Thank you! you run rich from the factory and having an intake will not hurt the car but its not going to add to performance either. save and get a few more mods then put them on and take it to get it tuned. he dont need to switch back to the factory intake box either. simple, if your hitting fuel cut take it to get it tuned or just dont drive it hard or switch back to the factory box. unless he is hitting that stock preset limit he should not be worried cause the stock fuel cut is preset really low, he will hit that way before he runs lean enough to pop somthing.
Originally Posted by jasnm21
Sorry but I disagree.
Think about it like this, from factory they run pig rich, an intake at the same boost levels isn't going to lean him out above 11.8 without more boost. I have personally tested this on a few local evo's and my own evo with minor mods. The AFR were never over even 11.0 let alone anything to cause damage.
You're right, our cars do run pig rich from the factory, but on some cars a cone filter or intake system can screw up the MAF readings enough to make you hit fuel cut, which it seems is happening to him. If you are hitting fuel cut, you need a tune.
Old Jul 21, 2010 | 12:43 PM
  #48
ETS Michael's Avatar
If your going to get a tune with the intake you should atleast op for the LICP as well. The LICP will give you a decent gain since the stock one reduces down to 1.75"
Michael
Old Jul 21, 2010 | 01:59 PM
  #49
FJF's Avatar
FJF
Michael
What does the coupler on your LICP reduce to?
Old Jul 21, 2010 | 02:33 PM
  #50
1.8"
ETS vs Stock
The turbo outlet pipes fits inside of it and actually reaches the funnel which is larger then 1.8"
http://www.extremeturbosystems.com/M...duct_info.html
Thanks!
Michael
Old Jul 21, 2010 | 06:39 PM
  #51
BoostFTW05's Avatar
see we agree lol
AC
Old Jul 21, 2010 | 06:41 PM
  #52
BoostFTW05's Avatar
1.8"
ETS vs Stock
Thanks!
Michael
I need to pick one of these up asap.
Old Jul 21, 2010 | 08:27 PM
  #53
jasnm21's Avatar
He would have to clarify what he meant by "getting spikes." He could just be looking at a boost gauge and seeing higher boost levels than before and was worried that it might do damage because of the extra 2 psi or "spikes" as he said.. That is how I took it. If he is hitting fuel cut off then yes, of course he needs a tune but I don't think he is hitting fuel cut off.
But I really think he should get a MBC, LICP and possibly cams before getting a tune.
Old Jul 22, 2010 | 10:07 AM
  #54
Craig King's Avatar
Originally Posted by Tommy_Lee
i couldnt find perrin intake anywhere, its discontinued...
Says who? I just ordered one 2 weeks ago and installed it last week.
whatever you say cheif.
Learn how to spell, chief.
Old Jul 22, 2010 | 11:41 AM
  #55
Tommy_Lee's Avatar
Driveline told me they dont carry it and so did speed element.
But as of right now i just ordered a Buschur MBC+Full intake.
Old Jul 22, 2010 | 11:52 AM
  #56
xmaciek82x's Avatar
Just cause some vendors don't carry it anymore doesn't mean it was discontinued. Should have went to the source: http://www.perrinperformance.com/
Old Jul 22, 2010 | 11:54 AM
  #57
JDMevoBOOST's Avatar
Stop being cheap....you're just gonna damage the car being cheap and running with no tune.
Old Jul 22, 2010 | 02:20 PM
  #58
Tommy_Lee's Avatar
im getting a tune next week lol
Old Jul 22, 2010 | 02:39 PM
  #59
4g63Moon's Avatar
TBE,Intake,MBC,FMIC with IC pipings and a tune Go for it!
Old Jul 22, 2010 | 10:49 PM
  #60
EvOstyleZ's Avatar
Why not just put a KN filter on the stock intake pipe?
Thats what I did, no problems at all...
