blown headgasket?
Old Jul 23, 2010 | 11:21 PM
brenner's Avatar
blown headgasket?
Tonight during some spirited heavyfoot driving, my temp shot up. After shutting down, checking the overflow... it was FULL. Didnt look milky, and neither does my oil.
I let the car cool for a while, drove home gingerly, but tested it a few times. Every time I boost it, temp goes up.
Car is an 8, with 9 turbo, cams, bolt ons, 26 psi, 360 ish awhp.
Has full Koyo rad, and I have never ever had the temp needle move on my before.
Headgasket?
Bren
Old Jul 24, 2010 | 05:36 AM
bbyevo8u's Avatar
that is a classic sign for blown headgasket!
Old Jul 24, 2010 | 05:45 AM
turbo dragon's Avatar
yup sounds like the head gasket
Old Jul 24, 2010 | 06:43 AM
brenner's Avatar
Ok, gonna do further investigation today. Another point... Idle was hunting between 800-1100 after, wouldnt settle down. I assume this is another sign of a headgasket problem and the ecu dealing with the heat.
Edit - now that its light out, double checked some things.
Oil - normal
Coolant resevoir - normal
Coolant in radiator - tiny specs of stuff floating, miniscule and doesnt look "oily" (full flush with rad install april.)
Plugs - fine
Compression - 151-150-146-150
Car idles perfect today....
b
Old Jul 24, 2010 | 07:37 AM
brenner's Avatar
anyone?? still thinking headgasket?
Old Jul 24, 2010 | 07:55 AM
FedEvo8's Avatar
Thermostat?
Old Jul 24, 2010 | 07:57 AM
brenner's Avatar
thats what im starting to think now too.... just weird that it decided to act up right when i was being a dink with the car.
that should be an easy enough try to fix. i assume there are lower temp t-stats available.
Old Jul 24, 2010 | 08:23 AM
EvoTio's Avatar
Unfortunately those were the first signs when I blew my headgasket on my Talon AWD. My compression readings were pretty much even all the way across. The symptoms only became worse with time. I would also check the thermostat first just to be on the safe side.
Old Jul 24, 2010 | 09:10 AM
still*boostn's Avatar
always replace the cheap stuff first, duh.
plus head gasket isnt to too much work. give you something to do one night.
Old Jul 24, 2010 | 09:27 AM
brenner's Avatar
and an excuse to do ARP's.
thanks for the input. drove it to work today, temp creeps up if i put my foot in it at all, not a good sign.
Old Jul 24, 2010 | 11:07 AM
Evo8luva's Avatar
You might want to have the head checked for warpage too. Also take a straight edge to the deck of the block, extreme HG failures CAN damage the block. More than likely your block is ok, heads are usually "iffy" after a head gasket failure.
Old Jul 24, 2010 | 12:17 PM
brenner's Avatar
forgot to mention, took the rad cap off when it was hot. didnt pssssshhhhh like usual. seemed to be lack of pressure.....
im leaning more towards blockage, most likely at Tstat but I am having trouble finding one in Canada.
Any idea what thermostat that ours crosses over to? I read somewhere v6 eclipse 3.0??
Old Jul 24, 2010 | 12:29 PM
erald01's Avatar
do a leakdown test, it will take u only a cpl of min
Old Jul 24, 2010 | 03:07 PM
brenner's Avatar
found a tstat, did a parking lot install at work. seems ok!!!
Old Jul 24, 2010 | 04:03 PM
EvoTio's Avatar
You'll know within the next couple of days if the thermostat was the culprit. Did your old thermostat look deteriorated? Was it physically stuck shut? Good luck again, hope this was just the problem.
