valve relief size of 4g63 head
ok, so a buddy of mine suggested to fill the reliefs in the head with alcohol and then measure the volume of the fluid. not a bad idea so im going to try this today.
assuming that works, im fairly sure this formula should give me the numbers im looking for:
Compression Ratio =
Cylinder vol. + clearance vol. + piston Comp. vol. + gasket vol. + chamber vol. divided by Clearance vol. + piston vol. + gasket vol. + chamber vol.
or does anyone have another method of doing this?
Compression Ratio =
