Service Engine Soon light?
Old Nov 20, 2003 | 07:55 PM
jlam's Avatar
Okay, anybody had their EVO "service engine soon" light go on? What the f**k? I only got 4500 miles and so far, all I did was stick on a Blitz Turbo Timer.
If you had that light come on, what happened?
Old Nov 20, 2003 | 08:24 PM
BluEvo3037's Avatar
Yo...I had it on before...Did you check your intercooler spray water??? If its low the light comes on...Just fill her up and you'll be good to go..
-John
Old Nov 21, 2003 | 05:39 AM
RTW EVO's Avatar
just reset the ecu... run on search on how to do it... everything is fine... it's just like the required maitenence light in honda's just needs to be reset... the dealer usually takes care of it when you get your oil changed...
Old Nov 21, 2003 | 06:12 AM
EVOLUTION/RC51's Avatar
I wouldn't dismiss it that easily. Better to have the code pulled than be sorry. Find someone with scan tool or take it Auto Zone and have them pull the code for you. I got a P0300(Random misfire) code three times but everything was cool.
Old Nov 21, 2003 | 12:22 PM
jlam's Avatar
Thanks y'all. I appreciate your help!
Old Nov 21, 2003 | 12:37 PM
EVO_ATE_U's Avatar
dude,
very easy fix, just shut car off..open gas door remove cap and replace cap and re-start car.
the car is equipped with a pressurised gas system..and sometimes if u dont put cap on properly that will cause this.
try it ...no gurantee but this should work.
it happened to me....and that was how i fixed it.
later
