Rebuild kit for Exedy carbon twinplate?
Old Aug 4, 2010 | 07:37 PM
joyce1bro's Avatar
Hi all
I have the above clutch which is poked and I wanted to rebuild it as a non carbon clutch.. Can anyone tell me if its possible to do the switch??
buy something like this
http://www.awdmotorsports.com/index....mart&Itemid=29
OR
http://www.turbowholesale.com/produc...roductid=15143
I have been told I need a new floater plate to.
I have tried contacting my local exedy dealer (in new zealand) and they have no freakin clue that exedy did rebuild kits for anything....
Old Aug 4, 2010 | 07:54 PM
RSMike's Avatar
want to get something like this done?
flick me a PM on MMC and i'll see if i can help
Cheers, Mike
Old Aug 4, 2010 | 08:03 PM
joyce1bro's Avatar
you are the mantis mike =)
you have PM on mmc buddy
Old Aug 4, 2010 | 08:25 PM
KenMasters's Avatar
That ring welded on the pp02??? I didn't think you could turn that plate. And how do you intend on re fastening the springs on the middle plate?
Old Aug 4, 2010 | 08:34 PM
RockmanX's Avatar
you cant go from carbon to anything i found out today lol i have a defective exedy carbon its like 1100 to rebuild it might as well buy anew clutch. also you cant go from regular to carbon without replacing everything found out today from strictly modifed and his exedy rep
Old Aug 4, 2010 | 09:06 PM
joyce1bro's Avatar
^^how is that possible?? you can go from normal to carbon but not the otherway around??
Old Aug 4, 2010 | 09:29 PM
RSMike's Avatar
yes
Huh?
They aren't needed for the clutch to function, it's mainly for reducing chatter
Old Aug 4, 2010 | 09:36 PM
RockmanX's Avatar
TYPO lol cant i corrected it
Old Aug 4, 2010 | 10:12 PM
joyce1bro's Avatar
^^ ok that sucks... =( damn it!!! Thanks Rock
Old Aug 4, 2010 | 10:49 PM
RockmanX's Avatar
no problem save you the time and headache i had
Old Aug 5, 2010 | 03:22 PM
KenMasters's Avatar
Was the plate manufactured like that? I've never seen one like this. I thought it may be for resurfacing purposes.
Old Aug 5, 2010 | 03:34 PM
RSMike's Avatar
no, it was modified to shift the pivot point and increase clamping pressure.
the clamping pressure was moved from 2400lbs to ~3900lbs.
this allows for higher torque holding without the need for high friction clutch material. So it still is easy to slip, and you wont destroy your pressure plates.
Old Aug 5, 2010 | 05:25 PM
KenMasters's Avatar
How did you calculate the tollerances to know the height and thickness of the ring? Also did you have it balanced?
Old Aug 5, 2010 | 06:07 PM
RSMike's Avatar
i didn't, it was modified by a clutch reconditioning shop.
They have done this modification many many times.
it's already been proved on a 420+kwatw (560whp 1.0cf) Mazda GTX (with evo running gear and engine)
Yes it was balanced, along with my crank and crank pulley etc. Full rotating assembly.
Old Aug 5, 2010 | 06:26 PM
RSMike's Avatar
Originally Posted by ToxicFab
Stupid question but why weld the ring? Is there a point to it?
Thanks
as above
