Quartermaster Twin 3rd gear high rpm lockout
Following all instructions found here: https://www.evolutionm.net/forums/ev...djustment.html I STILL am experiencing trouble shifting into 3rd at over 7500rpms. This is driving me nuts. Any help?
I most certainly hope not considering it was just fully built by Dogbox Racing here in NJ. 3rd gear shifts perfectly fine under 7500rpm as do the other gears. Should I maybe re-bleed the whole system?
im just bumping this cuz at the track my QM was locking me out of 4th.
brand new BR tranny, and clutch only has around 1500 miles on it..
i have adjusted the pedal and bled my clutch since then, but havent been back to the track yet with it..
if adjustment doesn't seem to help and you have made sure there is no air in the system and it only seems to happen in 3rd gear then its most likely internal...(good possibility fork or synchro)
