STM clutch fork stop?
Old Aug 10, 2010 | 06:19 PM
ToxicFab's Avatar
Ok so I have looked and cant find a install on it. I'm curious about this. I have a cusco exedy twin and a stm clutch fork stop. I'm about to do my 5spd swap and I'm wondering sense there's no instructions included how to install/just the little nut and bolt properly. Do you just bolt it up and it works? Or do you have to adjust it car spacific?
Thanks
Old Aug 10, 2010 | 06:22 PM
sho669's Avatar
I set mine so that the bolt barely touches the fork when the clutch is all the way out.
Old Aug 10, 2010 | 06:56 PM
EmeryatSTM's Avatar
Once installed the bolt head should be between 1/8 - 1/4 inch away from the fork at rest.
Thanks for your support.
Any time you guys need help please don't hesitate to call us.
-Em
Old Aug 10, 2010 | 07:01 PM
ToxicFab's Avatar
Okay sounds good. Maybe some pics?
Old Aug 10, 2010 | 07:02 PM
sho669's Avatar
Thanks Emery! I'll be sure to readjust mine.
Old Aug 10, 2010 | 07:22 PM
ToxicFab's Avatar
Do you have pics of how its adjusted when ur done for reference?
Old Aug 10, 2010 | 07:49 PM
sho669's Avatar
Cars apart now, doing a full rebuild. Just a quick check with a tape measure is all you need, set it and forget it!
Old Aug 11, 2010 | 11:19 AM
ToxicFab's Avatar
thanks i think i got it
Old Jan 5, 2011 | 04:45 PM
I4UnderPressure's Avatar
Bringing an old thread back, do the clutch for stops pretty much cure the need to go to a push type clutch? Or are there other benefits?
Old Jan 5, 2011 | 07:30 PM
OsideEVO's Avatar
i need to pick one up.
Old Jan 5, 2011 | 08:02 PM
RockmanX's Avatar
great part for real i have it on the blue bomber
Old Jan 5, 2011 | 08:38 PM
localtoys73's Avatar
anyone have pics of the install?
Old Jan 5, 2011 | 10:59 PM
Celica2EVO's Avatar
Its not the same as going to a push style but it makes the main problem with the pull style non existent.
A push style clutch can be shifted faster and is usually smoother. The problem is they can also be harsh on the driveline because they grab harsher and cant be slipped.
The problem with the pull style on the multi-plate clutches (mainly exedy) is the clip that holds the TOB to the clutch cover, on a fast shift it can break which leads to hundreds of dollars or hours in the garage to fix. This part gets rid of that chance.
Old Jan 6, 2011 | 04:17 AM
That's mainly the info I was looking for. I am doing a clutch this spring and will be doing 90% street driving 10% at the drag strip just to see what she does. So I'm trying to find the ideal setup. I was thinking exedy twin hd with the clutch fork stop, but have not yet decided.
Old Jan 6, 2011 | 06:49 AM
monkey_187's Avatar
^^ if you have the Exedy twin, trust me get it! I didnt have it and the f**king snap ring came off on me twice already. You have to take off the transmission just to get it back on. I would not recommend using the same snap ring but thats me. I got another one and installed the CFS so far I have had no problems with it.
