1200cc
Old Aug 12, 2010 | 11:46 PM
kingkorea76's Avatar
1200cc
quick question guys 1200cc injectors enough to run e85
Old Aug 12, 2010 | 11:49 PM
L888Apex's Avatar
depends what turbo?
Old Aug 13, 2010 | 12:25 AM
ill be running a fp black
Old Aug 13, 2010 | 12:27 AM
L888Apex's Avatar
in that case no.....
Old Aug 13, 2010 | 12:52 AM
so what would i need then
Old Aug 13, 2010 | 12:32 PM
DeatschWerks's Avatar
1200cc injectors should provide enough fuel for around 450whp, depending on your measuring methods of course.
Old Aug 18, 2010 | 12:24 PM
L888Apex's Avatar
for an fpblack on e85 you're gonna need a double pumper and probably some 1450's or larger
Old Aug 18, 2010 | 12:27 PM
evolution2186's Avatar
It's always good to have a bit larger injector incase of future upgrades or increased boost. I have a set of 100% new FIC 1650cc's for sale. $410 shipped, the box has been opened but the injectors are still in the sealed pouches.
Old Aug 18, 2010 | 12:40 PM
ravnos04's Avatar
+1 on 1450s, i hear the FIC BlueMax are good. GL
Old Aug 18, 2010 | 12:43 PM
MR.Evo.06's Avatar
sorry to jump in on your thread, but are 1200cc and a double pumper suffice for a FP Red?
Old Aug 18, 2010 | 12:46 PM
L888Apex's Avatar
that setup will do ok unless you're boosting ~28psi because after that point you will be producing numbers that will need your short block to be built. Unless you don't mind your motor blowing after a couple of monthes.....
if you plan on upgrading the internals and boosting it up to 32-34psi then I would suggest just buying 1450's as well
Old Aug 19, 2010 | 03:23 PM
fabshopmiami's Avatar
Just go with larger than you need for future upgrades.
Old Sep 3, 2010 | 08:08 PM
outtanowhere's Avatar
Make sure you have big enough fuel lines for volume. Dont want to lean it out.
1SlowRS
Dec 7, 2016 12:05 AM
shmagi
13
Nov 29, 2016 10:46 AM
shmagi
26
Apr 21, 2016 10:52 PM
EVOlution561
Mar 26, 2016 07:57 AM
mpfcc
Sep 17, 2009 11:27 PM
