Horrible Idle...
Horrible Idle...
OK so recently, I've just been idling like absolute crap. Idle is currently set at 800rpm and anytime I come to a stop, it dips down to 400-500 (low oil pressure and just wants to die). It'll just sit there for a while before the car kicks back up and then it might drop back down again and possibly die or it might stabilize the idle. This problem seems to have just suddenly come about because I had the same tune before and it was idling just fine.
So symptoms in a nutshell:
400-500 idle...sometimes dies (especially on cold starts, then it REALLY wants to die)
Extremely lean AFRs (20.5+:1)
Low oil pressure from the terribly low idle
Car eventually fixes the idle if I sit there for up to two minutes
Mods that might matter:
Cosworth M3 cams
Walbro 255
Stock injectors
AMS fuel rail
Again, I was fine on this tune for a while and then it just went to ****.
Any help at all is appreciated...I'm tired of having to feather my gas pedal at red lights.
EDIT: I haven't checked for codes yet because my CEL is always on so I'll probably do that if needed unless someone knows the problem off-hand.
EDIT x2: And when I punch it, it doesn't feel like there is any loss of power compared to normal. Hope I've narrowed it down enough haha.
Cosworth M3 cams
Walbro 255
Stock injectors
AMS fuel rail
Raised the idle to 950 and it's still doing it...only mod that has changed is a Cusco suspension brace.
Friend is saying that it could be a boost leak...any thoughts?
Thanks guys...
Thanks guys...
Did your vacuum on your boost gauge change? Since this was not always the issue, raising the rpm is only trying to mask the real problem.
yes egr hose check and if not, im sorry if i didn't read this, retard the mivec in the idle cruise. also check and adjust your BISS screw on the TB. turn it counter clockwise to raise your idle to help it catch. do it a small amount at a time to keep the car from revving to high at idle.
i would say do the basics first: boost leak test, check your vacuum pressure, check your spark plugs etc. All the basics then go from there. if your mods havent changed, then something is def wrong and or has changed. check the egr like others have said, maybe a line popped off or is leaking.
like someone else said, raising your idle may only mask the problem, especially if doing so already hasnt helped. gl and keep us posted. gl
you changed your intercooler too, when you did the brace. just want to add that info even though it mite not have anything to do with it
did you retune after puttin the stock intercooler back on?
and you have bald tires but thats another story haha
GL babs
GL babs
not for noting but your crazy for driving your with these conditions your askinjg for trouble having your afr's at 20,oil light coming on when slowly down,and getting on it wot is plain dumb i'm sorry just looking out.As far as your issue goes go to auto zone and have them scan your car for the cel light it's free of charge find out what it is.I think your maf is bad that's the symptoms or icv (idle control valve)bet you it's either one.,
Thanks but I'm not that crazy...
