need help with waistgate
Old Aug 18, 2010 | 06:24 PM
turbo dragon's Avatar
Im fixing to buy a bigger turbo and an external waistgate, should I have the WG recirculate or open dump, a friend told me I would get more power from running it open dump, is this true cause the only reason I didnt want to do the open dump is because a guy I know almost came off a dyno cause the dump burned through the straps. thanks guy
Old Aug 18, 2010 | 06:30 PM
bluebanana23's Avatar
Wastegate > waistgate. Open dumps help with more power and do a better job controlling boost creep but at the cost of noise.
Old Aug 18, 2010 | 06:51 PM
yeah the noise is the other reason I didnt want to do it but at the same time I want to get all the power out that I can
Old Aug 18, 2010 | 08:40 PM
TeStUdO's Avatar
If you're "fixing" to get a bigger, non-stock frame turbo, open dump is the way to go. Re-circing correctly (at least 18" from the turbo) is a pain to to do and not worth it.
Old Aug 20, 2010 | 02:26 PM
awesome thanks guys, Open dump it is
