Cooling issue
Old Aug 23, 2010 | 05:41 AM
EvoVIIIFL's Avatar
Cooling issue
Well here's the basics on the car:
Fully built 2.0L motor
GT37R turbo
slim line radiator fan
factory radiator
factory thermostat
104K miles on the chassis
Last week car was running normal as I sat at work waiting for the Mrs. and no A/C running.. after about 10 minutes decided to kick the A/C on... after a minute or 2 notices AC not as cold as normal.. looked at temp sensor.. 3/4 way up.. FAWK!!
Coolant was boiling in the overflow bottle and out the tube... let it cool down looked over everything(carefully) let the rad fan run with key in on position but not running obviously. Drove home.. checked.. had a friend come over with a younger thermostat 40K miles Swapped out.. checked it no issue(coolant was added) ran car idle for awhile then A/C on... no issue.. got on it 20psi(low setting) no issue no white smoke. Figured just sticky thermostat since had alittle corrosion on it.
Fast forward to yesterday. Sitting waiting to pull into traffic car started climbing with AC off... ****! turned car off for a second..turned on.. and everything fine fan running no issue. Got home let it cool checked nothing in the overflow other than alittle coolant.
My theory is this:
Radiator fan relay possibly going bad intermittently? Was thinking about replacing it and the coolant temp sensor since both are 104K miles on them. Any other ideas? I thought headgasket since its got 60K miles on the built motor, but no white smoke no bubbles in coolant...
Old Aug 23, 2010 | 12:14 PM
EvoVIIIFL's Avatar
anyone?
Old Aug 23, 2010 | 08:03 PM
Appauldd's Avatar
Sounds like maybe the temp sensor for the fan control might be going bad. Or, like you said, the relay is going away.
Old Aug 23, 2010 | 10:09 PM
02-Lancer-Es's Avatar
My Lancer does the exact same thing , only does it going slower speeds at random after i had just been in boost with the ac on (100 degree weather) (16g turbo charger set up) i am going to try and replace my water pump to see if that fixes it since i still have my oem pump .
Old Aug 25, 2010 | 06:11 AM
EvoVIIIFL's Avatar
Well looks like I'm going to just keep an eye on it and see if it does it again... nothing as of yet and if it happens again I'm going to pull over fast and see if the fan is running or not.. if it does it and fans not running I'll replace the relay. As for now everything is ok and has been. Go figure.. damn gremlins.
Old Aug 25, 2010 | 07:51 AM
If it helps mine are also running when it happens
Old Sep 3, 2010 | 08:29 PM
outtanowhere's Avatar
Most of the time its the coolant temp sensor that signals the ecu.Make sure ther is no air in system because it wont be able to read the water temp and turn the fan on.
Old Sep 28, 2010 | 11:12 AM
DarksideZ's Avatar
If all that fails, it's time for a leakdown test.
Old Sep 28, 2010 | 11:20 AM
CBRD's Avatar
Are all of your grounds hooked up? Also log ur coolant temps, don't trust the dash gauge. We have seen the gauge on the dash go almost the entire way up while the ecu logged temps are 190 degrees because of a bad ground issue.
Cb
Old Sep 29, 2010 | 05:20 AM
EvoVIIIFL's Avatar
Cb
Figured it out. For WHATEVER reason the drain plug for the radiator (factory rubber one) is leaking.. completely screwed in but still leaks.. guessing the threads are crap. Do you think Teflon tape will work to better seal or any ideas? Not a nasty leak but a small slow one that after awhile enough air is in the system..
Old Sep 29, 2010 | 06:57 AM
EvoooB's Avatar
Time for a CBRD slim rad!
Old Sep 29, 2010 | 07:00 AM
DarksideZ's Avatar
Sales Pitch!!!
Old Sep 29, 2010 | 07:01 AM
EvoVIIIFL's Avatar
Maybe if Chad hooks me up... he still owes me a shirt from back in the day before he opened the shop!
Old Sep 29, 2010 | 07:53 AM
CBRD's Avatar
Lol PM me lol
Old Sep 29, 2010 | 07:59 AM
EvoooB's Avatar
Originally Posted by DarksideZ
Sales Pitch!!!
I dont even work for CBRD! I just have one of their slim rad's and it is the ****!
