need help with build
Old Aug 23, 2010 | 08:36 PM
Ginglingston11's Avatar
i know first step is to search, i have and cant find sh*t. well heres my problem, my next move on the car is build the head. right now i have a stock motor with only arp head studs (to be installed), fp red, aem ems, aquamist meth kit, and all the supporting mods. first off i still need a tune with the meth and ems. but anyway im not looking for power on paper you could say, i want a nice hard pull all the way through the powerband. at the point i should be around 500 wheel (im taking a good guess) with the meth and ems. i DD my car and want to get back into going to the tracks every week like i use to. so i need your help do i go with 272s or 280s? im most likely going with the kelford 280s and fp valve springs unless im told other wise. thanks for the help in advance
Old Aug 23, 2010 | 09:58 PM
xcelr8's Avatar
I think the kelford 272 will be good enough. You dont need too much duration but more lift. Longer duration for the bigger turbo's. Check out TTR for a tune
Old Aug 23, 2010 | 10:01 PM
evolution2186's Avatar
Any reason you won't be sticking with the ECU flashes? You can make plenty of power on the stock ECU. I would personally say to put your cash towards another part.
Old Aug 24, 2010 | 06:44 AM
i understand i can make plenty of power on the stock ecu, but i had the money and it was a great deal so i took it. and to be honest ive been looking into an aem ems for the longest.
and back to the cams, i thought bout the 272s but Ivey told me i wouldnt see more than 15 wheel over the stock Mivec cams
