turbo blade chipped? large pic inside, need your thoughts.
Old Sep 1, 2010 | 07:13 AM
TommiM's Avatar
if you look closely on the bottom compressor blade I noticed the other day was chipped. I have no clue other than the turbo picked some debris and got chipped. Whats strange is I still have a stock airbox using a cosworth panel filter. Anyhow, just want your input on whether turbo shoould be replaced asap or ok to wait a few months to save up for something bigger? It boosts and runs fine but I am taking it more carefully and watching it so it doesnt get to the point where I can possibly damage more expensive parts.. Thanks guys.
--I realized the pic wasnt as large as I thought it would have come out.
Old Sep 1, 2010 | 08:50 AM
turbolarry's Avatar
That damage is not bad. I wouldn't worry about that as it is. As long as it spins freely and doesn't hit the compressor housing I'd go with it. Have you noticed a drop in boost? If it starts rubbing, or if you want things to be perfect, then go ahead and rebuild it.
94AWDcoupe's Avatar
thats a non issue. if you are worried you can take a small file and remove small amount from opposing blade to keep balance. but I wouldnt even do that. its not big enough chip
Old Sep 1, 2010 | 09:04 AM
nyquil2's Avatar
lol... it takes away from the balance and flow but should still work
silentkiller
Dec 8, 2013 01:36 AM
urslo4n8
Feb 9, 2008 11:26 AM
Derek888
Sep 10, 2004 04:16 PM
digdat
Feb 24, 2003 11:58 AM
