HI,
just wonder is there anyway of identifying the upper and lower of the JE piston rings?
As i bought it used so i dont has the manual...
Thanks
Thanks
RSMike
close
- Join DateJul 2009
- LocationNew Zealand
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:372 Times in 147 Posts
upper rings are 1.0mm, lower rings are 1.2mm. they should only fit one way?
try putting the 2nd ring in the top ring land, you'll see what i mean...
Thank you so much Mike...Originally Posted by RSMike
upper rings are 1.0mm, lower rings are 1.2mm. they should only fit one way?try putting the 2nd ring in the top ring land, you'll see what i mean...
That's correct. The top ring is usually 1.0mm tall and is steel (somewhat shiny), the darker cast iron ring is the 2nd ring. Another simple test if you're not sure, is to drop the ring onto a solid counter top from a few inches up. If it makes a "ding" noise, that's the steel top ring, if it doesn't make much noise is probably cast iron and the 2nd ring. Originally Posted by RSMike
Quote:
Thanks for another great sharing...Originally Posted by SeanC
