sensor issue perhaps?
Old Sep 21, 2010 | 08:45 PM
BLK_EvIL's Avatar
Originally Posted by Fknfstevo
If it was the IAC, would that also cause the o2 readings to be .91 while cruising down the interstate? Or even going like 45 to school this morning they were .87ish.
Is this off a wideband or the stock narrowband sensor because narrowbands arnt acurate. I paid 48 bucks off ebay for a iac off a 2003 eclipse same part number.
Old Sep 22, 2010 | 01:03 AM
white_evo27's Avatar
i believe hes talking narrowband because its his TT connected to his ECU
Old Sep 22, 2010 | 11:25 AM
dastallion951's Avatar
well any check engine light ever come on??? if not since ur spark plugs were black thats a sign runnin too rich, id say have someone check ur fuel trims....or try cleaning out ur mass airflow sensor with electronic cleaner, you can also try cleanin the throttle body with throttle body cleaner.
Old Sep 22, 2010 | 11:41 AM
xsolowx's Avatar
You can actuate the idle control using tactrix cable and evoscan.have the car running and click the button to actuate it. If the car stalls you need to adjust the screw on the unit.
Old Sep 22, 2010 | 11:03 PM
white8's Avatar
Good to know!
Old Sep 23, 2010 | 06:52 AM
Fknfstevo's Avatar
Thanks for the post everyone. But, i'm not talking about the a/fs. I mean the o2 reading straight from the ecu is really rich, like 9-10 on a scale of 10.
Old Sep 23, 2010 | 06:55 AM
Fknfstevo's Avatar
My check engine light is always on b/c of the rear o2, plus i use it as a knock light. I had it checked a few times and its always the same. just the rear o2 shows up as being bad but, thats the wideband so nothing there. I thought if it was the iac wouldnt it be showing up?
Old Sep 23, 2010 | 01:38 PM
flymx771's Avatar
Sounds like your TPS is disconnected or not working.
Old Sep 23, 2010 | 08:26 PM
BLK_EvIL's Avatar
i never got i ses light wene my iac was bad
Old Sep 25, 2010 | 07:21 AM
Fknfstevo's Avatar
Hmm. I am changing both tps and iac later today in different sittings so i will see which fixes. I hope one does.
Old Sep 26, 2010 | 04:57 PM
BLK_EvIL's Avatar
updates any luck
Old Sep 26, 2010 | 05:01 PM
fareastkorean's Avatar
Hmmm. I'm having a weird start up issue. My car wants to stall right only when I start the car up so I have to give it a little gas. I believe I threw a code and it was for the IAC. To fix this, would I have to replace the iac controller and or iac sensor?
Old Sep 27, 2010 | 05:30 AM
xsolowx's Avatar
sounds like its out of adjustment....not opening enough for start up...do you have tactrix cable and evoscan?
Old Sep 27, 2010 | 06:48 AM
rcheung's Avatar
There is only one part for the IAC. Its that small black piece under the throttle body held in by three screws.
Old Sep 27, 2010 | 08:41 AM
No, but I have a friend that does. Is there something that we could do to fix this?
