Odd sound when I push in clutch
Old Sep 29, 2010 | 11:27 AM
nytalonTSi's Avatar
I've searched but nothing in comparison.
Pulling into work I push in my clutch to go into N and I hear this air sound kind of like when you use a air pump on a bike. I turned the car off to hear the air sound better and when I push the clutch in with the car off it does the same thing.
I checked the fluid reservoir it's full, no leaks in sight. I'm starting to believe it might be the clutch master and slave cylinders. 80k and their prob the original parts. I was gonna replace them when I put the car away this winter, but this is the first time I ever hear an air sound in any manual car I've owned if indeed a hydraulic part failed.
Any insight is appreciated, thanks.
EDIT: FOUND IN SEARCH
