How to install kaaz rear LSD with ACD ?
Old Oct 1, 2010 | 01:35 PM
HsamehH's Avatar
Hello,
i have JDM Evo7 that uses ACD system only but not AYC, and i decided to install Rear KAAZ LSD to 100% lock the Rear wheels,but i don't know how it will work with the rear wheels and ACD system.
any one have ideas about that installation with the stock ACD,Kaaz told me turn off the ACD system but i don't see that makes sense as it's just 3 options switch (tarmac gravel snow)
-do i remove the ACD System or the Rear LSD should be works with the ACD at same time,i am confused about this and i hope anyone can help me about it
Thanks guys .
Regards.
Old Oct 1, 2010 | 07:32 PM
barneyb's Avatar
I guess I don't understand why you think this would be a problem.
Old Oct 1, 2010 | 08:21 PM
Dallas J's Avatar
Veteran: Army
Separate systems, youll be just fine. Well, better than fine if the Kaaz locks ups better than stock (not 100% sure what the 7 comes with in the rear when not equiped with AYC)
Make sure to break it in (look up the process, gotta do figure 8's). Also, with DSM's they dont seem to last nearly as well as modded OEM diffs when using big sticky rubber (285 hoosiers), but will do just fine with street tires.
Old Oct 2, 2010 | 12:26 AM
HsamehH's Avatar
i don't think it would be a problem,i want to understand the installation process
i want to know if i just install it ? could the ACD function make any problem with the rear wheels ? kaaz told me switch off the ACD off,how can i switch it off ?
