Questions/OOpinions/Ideas Catch can
Old Oct 13, 2010 | 01:58 PM
Evolv3dEvo8's Avatar
Hey Evom. I have been doing some homework and searching on the forum about catch cans. Are there some people that can explain to me the best setup for an Evo VIII as far as line routing What to tap so on and so forth. whats the most efficient way to do this
what i have so far: An Evo VIII valve cover with 2 -10 an bungs on it one on the back and side. I was thinking of a Quart Moroso Catch can?? Like I said I'am open to ideas.... I want to tak advantage of a Proper working setup for my car.
Old Oct 14, 2010 | 11:04 AM
Davo's Avatar
let me help you b4 u get flamed for not searching lol
Saikou Michi is one of the best you can use as it has a strainer to really remove the oil moisture from the incoming air flow.
The PCV would have the most blow by and should be the 1st line to intercept and catch oil from. Line should be lower than the PCV outlet to ensure flow occurs and nothing backs up.
The line from the charge pipe side to the intake tube, well in my case was dry and thus useless to tap to catch anything from.
Hope this helps.
