Spark plug cover bolts
Old Oct 16, 2010 | 07:13 PM
Spac3clown's Avatar
Question Spark plug cover bolts
I have a question regarding the bolts that hold down the stock black spark plug cover plastic piece. When I purchased my car the two bolts on the right side were snapped off at the head(head of the bolt) and I am looking at getting whats left of those bolts out of the valve cover.
Do you think its possible to get those bolts out if I remove the valve cover or will the entire valve cover need to be replaced with a new one?
I can post pictures up if that helps.
Thanks
Old Oct 16, 2010 | 07:19 PM
SLO-EVO's Avatar
Removing the valve cover won't do you any justice. Your best bet is to get a punch or file and try to score the head to be able to put a screw driver into it and back it out. Another option is getting a small bolt extractor and pulling it out that way...
Old Oct 16, 2010 | 07:24 PM
SLO-EVO's Avatar
are you referring to the bolts highlighted in the white squares?
Old Oct 16, 2010 | 07:25 PM
Spac3clown's Avatar
The bad part about it is my car was in the shop earlier this year to get some parts put on and a tune. Well before I left the dyno I was told I needed a new head gasket. So the head was pulled and cams etc were added. I asked TopSpeed to see what they could do about the broken bolts while the head was off and they recommended that all I needed was a new valve cover.
I am pretty sure the mechanic should have noticed them while he was working on the head.
Old Oct 16, 2010 | 07:26 PM
Spac3clown's Avatar
The two bolts in the white squares would be correct.
Old Oct 16, 2010 | 09:43 PM
JohnDoe1984's Avatar
I would say try an ez out, but read this first.
http://www.brokentap.com/easy-outs.html
Old Oct 16, 2010 | 11:18 PM
ajstefanacci's Avatar
If the broke off flush and you can't grab them, try drilling them and then using an easy out. If they are sticking out any, id grab a dermel and turn them into flat head screws.
Tsensational
Jul 27, 2016 08:53 PM
xXANCHORMONXx
May 20, 2014 11:19 AM
richdmadman
Mar 14, 2013 07:32 AM
Locdizzel
Feb 4, 2011 06:10 AM
Lumpy
Lancer How Tos / Installations
Dec 18, 2007 01:51 PM
