Exedy Twin -Lockout gears
Old Oct 17, 2010 | 03:13 AM
EvoPower81's Avatar
Bought a used twin on some guy on the forum with the disc around 3.4 mm thick. I decided to put it in the car untill I receive the new replacement disc .The clutch was working fine once I adjusted the pedal but now its locking me out of gears and tight to go in when it isnt locked out. I figure that the disc were the problem as they were bought with less than half their life span but what has me puzzled is my engaugement point is no lower than before. Is this still the disc that need replacing , is it a sign of something warped (Pressure p, disc etc).
Old Oct 17, 2010 | 05:20 AM
EvoPower81's Avatar
Noone, I know these are popular clutches?
Old Oct 17, 2010 | 07:32 AM
Boltz.'s Avatar
FCOTM Winner
The intermediate plates warp very easily on those clutches. Did you inspect the parts with a straight edge to see if the were warped at all? This could prevent the clutch from disengaging which would lock you out.
Old Oct 17, 2010 | 08:31 AM
EvoPower81's Avatar
I have 2 new disc to install so I guess ill check them when I pull the tranny. Hope its just a case of worn disc as they were already less than 1/2 the thickness from new.
Old Oct 17, 2010 | 10:07 AM
GBAILEY472's Avatar
what rpm are you shifting at ?
Old Oct 17, 2010 | 12:46 PM
EvoPower81's Avatar
Actually sorry I should really explain better. I just doesnt wanna go in gear even to put it in 1st to move off. Sometimes i have to scitch off, put it in 1st then start it in gear to move off. I did a reasonable amount of launches testing my 2-step and preparing for a drag meet. Wasnt like this before. Just wanna know if worm disc have these signs ao I could have piece of mind and I have 2 new disc to replace them with
Old Oct 17, 2010 | 12:50 PM
Boltz.'s Avatar
FCOTM Winner
Check the intermediate plates for warping. Save yourself the headache of having the trans in and out.
Old Oct 17, 2010 | 03:12 PM
EvoPower81's Avatar
I ll do that for sure when I pull the tranny. If they are can I get them cut or do I have to replace?
Old Oct 25, 2010 | 05:24 PM
fugiwara's Avatar
update?
matteclipse
Jan 27, 2014 07:02 PM
EVOjunky
Dec 15, 2013 04:13 AM
evo-tee
Nov 5, 2013 10:20 PM
Robertv34
Oct 19, 2013 10:22 AM
renc2000
Dec 19, 2011 02:21 PM
