Noobi3 questions
Old Nov 30, 2003 | 02:59 AM
X-Breaker's Avatar
Noobi3 questions
Hi all, I will be installing a couple of things on the car come Tuesday, and I'd appreciate your help with the finer points. Well, here goes.
-My vehicle is a JDM Evo6 GSR, and I was wondering if anyone knew:
-at what psi does boost cut occur?
-what boost pressure can the 4G63T handle on the stock internals, without upgrading the head studs?
-For those of you running an oil catch tank, where did you locate it and did you use the PCV hose to the IM, or did you locate it somewhere else?
-What is a good 12V source for a EBC? What are you using personally?
Please help, I am rather unfamiliar with the Evo6, and any assistance would be greatly appreciated!
Old Nov 30, 2003 | 06:31 AM
Serge03's Avatar
usually the Dimmer switch is a good place to run your boost controller off of, but you could also try the cigarette lighter power.
